tyho
1,326
946
toronto
2015 C7 Z51 M7
I did (partially did) a clutch fluid change. I tried the Rogers method I saw on another forum. My 2015 z51 M7 has about 16500 km. I sucked up the old fluid from the reservoir and it was brown. I replaced this with new DOT 4 fluid and pumped the clutch about 30 times between fluid changes. I used a syringe bought from CT so the amount removed and replaced would be the same. I cycled the exchanged about 8 times until the fluid started coming out fairly clear. I know the total fluid was not replaced but at least this cleans up the fluid somewhat.
For what I heard when I was on the hunt for mine that is the only way to do it. Suck it up and pump and change again if necessary. You should do this at least once a year and check the colour of the fluid every now and then. If it is dis-couloured then change again.
I got a paddle shift on mine.
