Question Change tires before delivery?
Airbus330
C7 Owner
Oct 3, 2018
7
5
Kitchener
2019 C7 Stingray 2LT
Province / State
Ontario
Hello all,
Ordered my first C7 Stingray 2LT last October and it was built last week. :) I've been following this forum and the other big forum since then and I want to switch to Michelin Pilot Sport A/S 3 as I would like to have a little longer driving season and don't need the full potential of the OEM tires. The question being, should I purchase the tires and have the dealer install, and then sell the OEM tires to one of you fine people? My thinking is that I can make buying the new ones less stressful on the pocket book and would be easier to sell "new" than a few thousand km's on them.
Looking forward to my first Vette soon.... and better weather!
SN-III
Making the Day Matter
Beta
C7 Owner
HOT Dealer
Oct 10, 2016
3,463
5,301
YYC - alBEERta
1
His & Hers C7s
Province / State
Alberta
... have to say no harm in trying to find a buyer (probably someone nearby) ... likely the fewer the kms on them the better ...
The dealer won't deal with you on them on a delivery swap-out? You never know if they want a set lying around (especially the larger dealers)
I've seen stacked sets in parts & accessory areas at two different dealerships.
They had a "term" used that people seem to trust more when at a dealership - I think it was "factory take-offs" - but unsure
  • Wow
Reactions: ccltj
dyoung
Mar 6, 2018
32
41
Sidney, Vancouver island.
2017 GS convert.
I too would try to make a deal with the dealer..
The tires would be worth more with no miles.
The a/s 3's will probably give you a smoother ride.
Good luck with the new car.
Jeffer2013
C7 Owner
HOT Dealer
Aug 1, 2013
798
734
alberta
2016 Base DSOM
Province / State
Alberta
spencer is correct
but maybe after the break in drive the crap out of the tires for the year and replace in the fall
(with or without new rims)
BEST ADVICE IS THE BETTER WHEEL ALIGNMENT I POSTED EARLIER LAST YEAR, cannot remember what the alignment was called, others will chime in
that makes the sides of the front tires last a lot longer
Jeff
SN-III
Beta
C7 Owner
HOT Dealer
Oct 10, 2016
3,463
5,301
YYC - alBEERta
1
His & Hers C7s
Province / State
Alberta
Can someone find that link for the alignment please and paste it here as I need to relatively know what I am asking for ... thank you
Jeffer2013
C7 Owner
HOT Dealer
Aug 1, 2013
798
734
alberta
2016 Base DSOM
Province / State
Alberta
I am in town but I posted it before so I will search my content in the next day or 2. The alignment works like a charm as long as u do not track,the,car and should be a sticky with the proviso warning for street only to increase normal type tire wear jeff
Reactions: SN-III
Airbus330
C7 Owner
Oct 3, 2018
7
5
Kitchener
Province / State
Ontario
Thanks for all the advice. I'll approach the dealer and see what they have to offer... but I kinda smiled and liked the idea Jeffer 2013 came up with!
Reactions: SN-III
ddgermann
6000 RPM Poster
Beta
C7 Owner
Jul 1, 2017
3,276
4,530
Edmonton
2017 3LZ Z06 Z07
Province / State
Alberta
Hello all,
I had the SC2s changed out to PSS by my dealer before I picked up my new Z.
I simply found the best price on the PSS tires and my dealer matched it.
The new SC2s have been sitting since. Wasn’t able to sell them on here for 1/2 price and haven’t bothered trying to sell them since.
Now the PSS that come on your car are much easier to sell as they are the preferred tire for most people due to the good performance, longer life and they are better in rain.
If it was me, and mentioned above, I would drive them for the first year at least. They are fine on 5 degree days as long as you warm them up a bit. It doesn’t take long and you will know instantly by the feel leaving a light or the indicator on your driver screen.
The alignment change may be a good idea as the car is set up more for the track from the factory. Mine is still at the factory settings but it only has 7000 km on these PSS tires so no issues yet. Although I see the wear on the rears seemed to increase dramatically over the past month of “cruising”. Oops 😬
Either way you’re ok.
  • Informative
Reactions: Bixter44
Rruuff Day
I think Spring is Close
Beta
C7 Owner
HOT Dealer
Aug 30, 2014
6,007
5,582
Pine Lake, Alberta
C7 3LT ZF1
Province / State
Alberta
If they are the Michelin Pilot Super Sports in Z51 sizes, I'd be interested in the tires if the dealer doesn't want them.
They will fit the Z51. The Stingray base switched to 245/35R19 fronts and 285/30R20 rears for all models after 2017. Those are also the Z51 sizes. Z06 and GS tires are 19's and 20' as well but too wide for the narrow body.
  • Wow
Reactions: ccltj
Rruuff Day
Beta
C7 Owner
HOT Dealer
Aug 30, 2014
6,007
5,582
Pine Lake, Alberta
C7 3LT ZF1
Province / State
Alberta
Hey Airbus330. Just a guess but you're likely happy you didn't pick 737Max for a name.... ;)
Airbus330
C7 Owner
Oct 3, 2018
7
5
Kitchener
Province / State
Ontario
Ya, when I made my first post today I realized someone would pickup on my handle.... As a side note, I’d get on any 737Max.
If I do switch tires on delivery, I’ll definitely put them up and I’ll only sell at a price to take a bite out of the new ones. Thanks for the info Rruuff Day.
For the camber settings, are most(any) dealers knowledgeable in why to change these?
Cheers
Rruuff Day
Beta
C7 Owner
HOT Dealer
Aug 30, 2014
6,007
5,582
Pine Lake, Alberta
C7 3LT ZF1
Province / State
Alberta
Cheers
I would venture that by now the dealerships should be aware and have enountered this alignment adjustment since many of both the C6's and C7's were, and some still are, set up more for performance handling than avoiding premature tire wear. At the very least, the alignment staff should know what to do. Especially if you have the settings.
Yeah. I wouldn't hesitate on the Max either. Hell, I still get on a Mk1 Beaver.
Reactions: turbozig
grandsp69
C7 Owner
Jun 25, 2018
94
188
’19 Grandsport
Congratulations to the OP! I bet you’re itching to take the car home 😂.
Pardon me while I hijack your post😛.
I’m going to ask my dealer to lower the car when they do the pdi . Will the pdaft alignment settings wwork on lowered cars?
  • Wow
Reactions: ccltj
Rruuff Day
Beta
C7 Owner
HOT Dealer
Aug 30, 2014
6,007
5,582
Pine Lake, Alberta
C7 3LT ZF1
Province / State
Alberta
There should be zero reasons why you can't tweak the camber and caster back to a less aggressive geometry on a lowered car.
grandsp69
C7 Owner
Jun 25, 2018
94
188
’19 Grandsport
I see how stupid my question is now lol. It was 4 in the morning I think when I asked that question. Thank you
Rruuff Day
Beta
C7 Owner
HOT Dealer
Aug 30, 2014
6,007
5,582
Pine Lake, Alberta
C7 3LT ZF1
Province / State
Alberta
.... No such thing as a stupid question here gs. Although we have occasionally been known to add some humour to our answers.... 🤣
