Ok, so this stuff was like pretty expensive and I was not sure if it would work. I found it on sale for %50 a while ago so I figured I would try it out. It's kind of like a ceramic coating with actually doing the ceramic coating. You just wash your vehicle, mix this stuff with water and spray it on, then hose it off. That's it. It works pretty good. I didn't use my Z06 for the vid as I'm going to ceramic coat that vehicle so I didn't want to put this on, only to have to remove it. It's really good at UV protection, so good at protecting the clear coat.
