I have a 69 vet which always 427 ran hot 454 solid roller ran hot now I have a 632 ready to go in do I use an oil cooler
Four core aluminum radiator will do the trick, which I put in my 74 and it always ran hot. Four core did the trickI have a 69 vet which always 427 ran hot 454 solid roller ran hot now I have a 632 ready to go in do I use an oil cooler
Sorry I had to check with my bro I couldn’t remember he says we had it made at Mr Radiator in Calgary but the owner has since retired and shut it down and that was 10 years ago. I am sure there will be a rad shop that could help you or a speed shop. Hope this helpsthanks I have a stock 390 hp 427 rad in it so I will try your idea with the stroker motor what brand did you use in aluminum
Stock, I think electric fans would be better as it saves horsepower. Even though it works very well stock or a high out put water pump.did you use electric fans or stock
I would say you are wrong about steel dissipating heat better. Aluminum has a higher thermal conductivity than steel meaning it is able to transmit heat easier through it. In fact it is something like 5 times better at transferring the heat. I would imagine all new cars have aluminum radiators since they can be made smaller with the same thermal capacity.
It is possible that a steel radiator has better geometry (or something) that allows it to cool better....but it wouldn't be the fact it is steel.
Just my 2 cents.
T
T
... Isn't there a brand of antifreeze that doesn't boil as fast as normal stuff ?
Suggested up top was removing the thermostat, my knowledge of that is if you circulate the coolant too fast it does not have a chance to cool down in the rad so you are basically circulating hot coolant without giving it a chance to cool any amount.
