I went through this with CAA before I stored the car for the winter.
This is what they sent me.
Here are the theft prevention options to remove or reduce the High Theft Risk Premium Surcharge.
1. 100% of the surcharge ($1,500) can be removed if you purchase an after-market engine immobilizer. You must have it professionally installed, the immobilizer cannot be seen, and a Code/PIN sequence or the immobilizer's fob must be used to start the vehicle. A Certificate of Installation and proof of purchase must be provided. (Ghost 2 or IGLA)
2. 50% of the surcharge ($750) can be removed if any of the following are professionally installed:
1. An after-market engine immobilizer not meeting the requirements above
2. An ignition cut off system
3. A two-factor authentication (2FA) system
Proof of purchase and installation must be provided.
3. The surcharge can be reduced by $500 if one of the following anti-theft deterrents is purchased and used regularly. A photo clearly showing it installed must be provided.
1. Steering wheel lock, Brake pedal lock, Wheel & tire lock
2. Retractable bollard
3. Key fob signal-blocking device (excluding faraday accessories)
4. If no action is taken, the full surcharge ($1,500) will be applied to your policy.
The cost to install the Ghost 2 or IGLA is around $1,200 to $1,500.
