Featured Thread
YFCvii
Beta
Oct 10, 2016
7,277
11,496
THIS WAS THE EASIEST SET OF SPLASH GUARDS / MUD FLAPS THAT I HAVE INSTALLED SO FAR !!!
DID NOT HAVE TO LIFT THE VEHICLE NOR REMOVE A WHEEL ... AND AN AWESOME MONEY SAVER.
So you gotta be just a little handy with tools to do this. You will need a 7mm socket and a cleaning cloth. The Splash Guard parts are listed on many on-line dealership accessory lists with an installed price of very close to $200 each for the front set and the back set. The parts purchase price from the Parts Counter for about $90 each pair. So a DIY install will save you 50%
I would recommend that you have the correct tool for this Job (a 7mm socket/wrench). Some might think to use pliers or an adjustable wrench to remove 1 bolt for each splash guard but I would not recommend it ... besides, I am always one to be front-of-the-line for a DIY project that endorses my having to add a new tool to my Tool Box. Having the right tools always makes it look like you know what you are doing (when the "boss" walks by - if you know what I mean)
I completed my Splash Guard Mod in about an hour; not including my picture taking and a break in-between to sit in a lawn chair and sip a pop while admiring the job that was 1/2 completed.
I am posting the instruction page and a few pictures of the install.
I would recommend to begin with the
FRONT SPLASH GUARDS
First I would recommend to wash the wheels and wheel well liners.
For the Front set, you will find one bolt on the underside to remove (photo below).
You will know which bolt to remove because you will be it fastening a tab of the factory wheel well cover.
Then you can use your fingers to grab the factory cover and pop it out (pulling toward the tire)
Be careful not to let the existing guard twist so that the retainer clips are able to rub (or scratch) your painted body side.
Once the bolt is removed the factory cover, wipe the area clean of debris that might remain behind.
To install the Front Splash Guard you will find that there is a tab that fits into a slot in the wheel well liner (see photo below). Make sure that you get the tab is in place before you start to clip the splash guard in. Missing this part of having the tab in the slot might result in this project becoming "Splash (mud) Flaps"! Be careful not to let the metal clips rub and scratch your painted surfaces. Once you insert the tab into the wheel well liner slot, pop the top retainer into its place. Then you can pop the retainers in place from top to the bottom. Then reinstall the bolt than you previously removed. You have now completed one splash guard installation. Repeat for the opposite front splash guard.
Now that you have taken a break to admire your front installations, it is time for the
REAR SPLASH GUARDS
Looking at the underside, you will likely find that there are 3 bolts. You will also notice that the tab that the bolt secures is not visible. I am hoping the photo below will help knowing that the bolt to remove is the one furthest from the body side (see photo). With the bolt removed, you can know pop of the factory cover with your fingers. You will notice that there is a slot where the bottom tab fit in and this is also where the bottom tab of your splash guard goes as well.
[/ATTACH]
Now with the existing rear wheel well cover removed you can pop in your new Rear Splash Guard starting at the top clip and working your way down. Making sure that you do not allow the metal clips to rub/scratch your painted surfaces. Making sure the bottom tab is put into the slot (arrow in above photo). Then replace the bolt that you removed. Repeat for the opposite side Rear Wheel.
I know many readers are handy and find this installation a no-brainer. A few would say this is so easy (because it actually is) but until you have done it, to others, "saying" and "doing" are two different things.
I am one that always pre-plans my approach to DIY. It's like making an awesome Homemade Chinese Dinner
"it's all in the preparation - as the cooking part just flows through" - yum ... I am hungry now!
Last but not least. My "boss" sometimes asks at one point during some of my DIY projects,
"Have you read the instructions"?
... so here they are ... :Banghead:
I am normally proud of my instruction pages that never have a dirt or grease mark on it.
All the ones that I do get dirt or grease on, is a reminder that I was an absolute "fumble fart" on that project.
This project has a clean instruction page (above) :thumbs:
Hoping you all enjoyed this ...
let me know if you find something I should mention on this so that anyone taking on this project will have a lot of confidence knowing what they are taking on ...​
SN-III nice post. I only have abt 110kms on my C7 and your post prompted me to order a set of front rear splash guards. The dont appear to look overly 'intrusive' to the eyeball.
I've put these on two C7's now (both Stingrays) with ease. They are not intrusive and look very much like something the Corvettes should have as a standard feature because I see it is the same part number that fits both Stingray and Z06. They also clean/shine up very nicely with "back to black" products (I use PERL from CarPro - see 2017 DIY Detail Thread). You should be very satisfied with these splash guards
Does someone have the PN for the fronts. I see PN for the rears in the instructions. So they fit both Stingray and GS/Z06 for front and rears? thanks
Front - Part [HASHTAG]#22935635[/HASHTAG]
Back - Part [HASHTAG]#22935639[/HASHTAG]
For 2014 to 2018
In Edmonton ... phone or go to Northgate (ask for Cory) (mention Spence from Calgary)
Reactions: rockitman
If you're thinking of adding rockers at some point, you might want to consider aftermarket front guards. They drop down the extra 3/4 inch further than GM's to keep rocks from pitting the leading edge of the rockers. At least mine do.
Just installed front and rear guards and glad I did. They don't look intrusive and blend in very nicely. SN-III got me motivated to do this with his original post. I only have 118kms on the Vette and may as well 'protect' it a bit from the start. I also installed the exhaust filler panel and am quite happy with the finished look. Exhaust will now look a lot better to those behind me.... LOL
“to those behind me”. Haha well put.
Please post a picture of the splash guards and the exhaust filler panel on Paul.
I et al would like to see them.
Thanks
Reactions: Rruuff Day
Thanks for the pics Paul. She's looking great.:thumbs:
Nothing you're doing wrong on the picture posting. Nik may comment as well but the three thumbnails you posted are the only ones within your post but when the thumbnails are opened, it picks up the full range of slides that have been posted within this particular thread. Next time, try posting the pics as a full image. Yours will be the only ones in your post and no one has to open the picture or look at the previously posted pics.
Reactions: ddgermann
Paul, I got bad news for you. Your meter is expired.
Nice job on the install.
When I saw the reply I was wondering what the heck is Black 03 Z06 talking about?! I then noticed the meter in the background, and you're right, it is expired! I better throw in a quarter... LOL
I kind of thought that but wanted to ensure that I was posting correctly. Thanks for the insight Rruuff Day.
That's a feature, honest guv... :)
