Hello,
... not a hypothetical situation ...
I have issues with 2 of 3 C7 Corvettes (2016 & two 2017s) ...
All while in Winter Storage
All 3 full-time on GM battery maintainers.
All 3 in an unheated Garage
Corvette #1
- key fob opens doors & remote starts (A8)
- not locked while in storage
- no apparent issues
Corvette #2
- will not remote start & will not push button start (fob not recognized)
- push button starts when the key fob is inserted in the steering column
- a multiple occurrence (not just one time)
Corvette #3
- always locked in storage & with all security features activated
- key fob will not open the doors
- (edit to add that) door pad won't work
- have to use manual driver door access thru the back hatch
- alarm sounds until key fob is put into the steering column
- as key fob is in the steering column - push button starts with no problem.
Now ... once the two cars start up and run for a while, I turn everything off
and use the remotes to lock & unlock - and it's as if nothing is an issue.
So question is, Should I consider key fob battery replacements first ?
(as I don't want to have anyone fiddle with the key fobs unless I really have to)
Or would this perhaps just be an abnominally due to unheated storage ?
Or it is what it is ... consider it a new normal ?
Or ... ???
... other than perhaps I may just need way more C7s to work with
posting this in the event that someone may have similar experience in the future.
Thx
Corvette #1
Corvette #2
Corvette #3
Or ... ???
Thx
