I have an ad in the parts classified section offering to bleed CAC systems for C7 Corvettes (Z06/ZR1). I can also bleed C6 ZR1 cars too using the cooler bleeder I purchased.
Check this post out also I did the dual CAC systems in my C7 ZR1 and yes if you have never had this procedure done on your C6 ZR chances are there will be air in the system robbing you of hp and causing heat soak to set in much more quickly.
Take a look at the listing in classified and also this post I did in C7 section:
Did my CAC system yesterday with Cooler Bleeder
Finally got around to doing this on my C7 ZR1 yesterday. Yup, from the factory these C7 Z and ZR's aren't properly done before they are sent to dealers FS. Glad I did mine took a whole bunch of air out of both systems now it's filled properly and no more worries about limp mode and heat soak...
canadiancorvetteforums.com
