Hi everyone !
My 2005 C6 coupe has this nifty automatic adjusting feature which, when working properly, lowers the window about half an inch when the door opening mechanism is actuated and just before the door latch releases (in order for the window to clear the top rubber weatherstripping, I suppose). After closing the door the system raises the window half an inch to the fully closed position.
Now, on the drivers side this auto-adjust stopped working. After closing the door, I have to manually raise the window the remaining half inch to fully close it. Although, when opening it seems to work and lower the window automatically, however, it's hard to tell because the door opens and window lowers almost simultaneously.
Does anyone have any idea where the problem is? Do I have to take of the entire door-panel to check the power window motor and sensors?
Many thanks for advice !
