- Feb 13, 2011
- 81
- 64
Nav system works,Radio works, CLOCK doesn't. No time shows. Battery was disconnected each winter. When reconnected this year no CLOCK. The adjustments are visible but only beep. Disconnect battery again and reconnected but to no avail. Is there a fuse I can check? If so which one? The one I will check is "RDO/S-Band, VIS. Thanks for you Help
