Hey all, considering purchasing the Hotchkiss 2285 sway bar kit for my 99 vert. I have a chance to pick up a stock set of C6 Z06 bars, but am basically running the stock size tires, and with the Z06 set up I have read that you should have wider tires when running the C6 Z06 bars. The Hotchkiss 2285 kit has almost exactly the same measurements as the C6 Z51 OEM bars. Am going to be changing out the plastic crappy stock end links that came with the car, so was wondering if anyone out there has used this kit, and if you noticed the difference. I will not be tracking the car. Just spirited driving.
