Have any of you had an issue of not being able to put your car in reverse. I had it on the road after 3 months of replacing everything from the rear main seal plate to the seals in the rear diff. I drove it for a couple of days. Had a little issue of not going into reverse, but it went away. Took it to work and when I got home could not reverse into the driveway. It went into reverse one more time after that and not able to since. I checked the connecter for power. I tried removing the spring inside the solenoid just to see if it would go in but still nothing. I am completely lost at this point any help would be greatly appreciated.
