Answered C5 fuel tank connections
2003 Z06
SK
I am wondering how the fuel lines are connected between the two fuel tanks. I understand that the fuel pump and filler hose are on the driver side. There is also a tank on the passenger side and the two tanks are connected together with a cross-over pipe. I presume there must be connections between the fuel pump and the other tank through/in the cross-over pipe. Am I missing something or is this how it works?
I found this....
The C5 Corvette has two fuel tanks, left and right hand. The left hand tank contains the electric fuel pump that supplies fuel to the engine. The right hand tank has a pump, which transfers fuel from the right tank to the left tank. The pump in the right hand tank has no moving parts and is not really a pump. It is a siphon device that uses fuel pressure from the left hand pump to start a siphon that transfers fuel from the right hand tank to the left hand tank. In order to create this siphon, the fuel line that goes to the engine splits and a small amount of pressure is routed to the right hand tank to start the siphoning. The fuel that is being siphoned is routed through another hose to the left hand tank. If the left hand tank is full, the fuel transfers back to the right hand tank through the large filler tube located at the top of the tanks.
The idea is to always keep the left hand tank full whenever there is fuel in the right hand tank. When the fuel gauge reaches a half tank, the right hand tank is empty and the left hand tank is full. Both tanks have a float and sender that measures the fuel level in the tank. These signals go to the Powertrain Control Module (PCM) which interprets the information and sends a signal to the Body Control Module (BCM) which then sends a signal to the fuel gauge in the Instrument Cluster.
Because of the variation in tanks and sending units, the PCM doesn't always read the actual fuel level in the tank. Above or below preset voltage limits, the fuel level is estimated. The voltage limits for each sending unit, right and left, are set to represent "full" and "empty." When one or both tanks have exceeded the preset limits, either "full" or "empty," the system is estimating the actual fuel level. This happens when both tanks are full, gauge is "full;" when the right tank is empty and the left tank is full, "half" on the gauge, or when both tanks are empty, gauge is at "empty."
This estimating strategy and the physical layout of the system results in an unusual fuel gauge characteristic that may be noticeable to some people. When the fuel level is at or near half tank, the right hand tank is empty and the left hand tank is full, so the system is estimating the actual fuel level. Because of the siphoning system, when the car sets without running, the fuel level equalizes in the two tanks. When the car is first started, the system is actually reading the fuel level in both the right and left hand tanks. After running for several minutes, the fuel in the right hand tank has been transferred to the left hand tank, leaving the right hand tank empty and the left hand tank full. The change in the fuel levels results in the system changing from reading the actual fuel level to estimating the fuel level. This change results in the fuel gauge reading actually indicating more fuel than when the car was first started.
One of the common concerns with the Corvette is the fuel gauge goes to "empty" intermittently. First, let's discuss why this happens. As previously mentioned, the system estimates the fuel level at certain times. When the signal from the left hand sender is above the preset voltage limit, the system estimates the left hand tank fuel level to be full. When the signal from the right hand sender is below the preset voltage limit, the computer estimates the right hand tank fuel level to be empty.
In this situation, left tank full and right tank empty, the computer estimates the fuel level and sets that gauge at half tank. Once the fuel level in the left hand tank goes below the preset voltage limit, less than full, the computer begins reading the actual fuel level and setting the gauge accordingly. At this time the computer expects to see the voltage signal from the right hand tank stay below the preset limit that indicates empty. The problem comes from the fact that the signal from the right hand tank does not stay below the preset limit. When the computer sees the right hand signal voltage exceed the preset empty limit, it assumes that there is a problem in the fuel transfer system, which is a possibility. When this condition exists, the computer software turns on the Check Gauges light and commands the fuel gauge to the empty position. The logic for this is, if there were a problem with the fuel transfer system and fuel was not being transferred from the right hand tank into the left hand tank, you could have the gauge indicate half tank, when then the left hand tank would be empty and the right hand tank would be full. In this situation you would run out of gas and be walking.
On some Corvettes the situation that is occurring now is the result of the right hand sending unit being attacked by compounds within reformulated gasoline. This condition manifests itself as an erratic voltage signal from the right hand sending unit. In the above scenario, left tank full and right tank empty, gauge at half, the computer looks for the voltage signal from the right hand tank to stay below a preset level. The erratic voltage signal caused by the reformulated gasoline causes the computer to think there is fuel in the right hand tank when there is not. When this happens the computer software turns on the Check Gauges light and commands the fuel gauge to empty. GM has issued a revised computer software, for 1999 through early 2002 models, that raises the right hand preset voltage empty limit to prevent the erratic voltage signal from causing this situation. While it has proven to be an effective solution, it has not corrected the concern in all instances.
Another possible resolution is to use Techron fuel system cleaner. This has also worked in many, but not all cases.
graham
Very interesting and complicated. Hopefully, I won't have any issues with the pump or sensors any time soon as it requires almost as much work to replace as replacing the clutch. I think the main ingredient in Techron is PEA and that is why I use Shell Nitro gasoline (no ethanol and contains PEA).
Just hope that you don't need to replace the fuel line that runs from the tank foward...I did about 5 years ago on my 98 C5 (just sold it for a C7), and my mechanic discovered that GM had discontinued the part! That's not the first time, and it bugs me doing this on a model that they know most of which will still be on the road many years from now. I wound up having to get a used one from a Vette wreckers in the US. That happened when the gas tank rotted out on my 78 C3 years earlier...no parts available.
Now.. if you wish to know WHY the tank is split into TWO ...
you have to read the book..
‘ALL CORVETTES ARE RED’.
The twin fuel tanks, run-flat tires and golf clubs are all related.
and how the first/BETA test drive had a flat tire in 100’.!!!
ha ha
graham
For some context, I found this video of Dave Hill and some of the other players involved with the C5 design.
Thanks, Graham. I ordered that book from Amazon. I presumed it was a weight distribution thing so it will be interesting to read the reasoning.
