The factory C4 Turbine/Salad Shooter Rims are labelled for use on the right or left side of the vehicle. My question is: will it cause damage or adversely affect handling if the rims are mounted on the side opposite to that indicated on the label (i.e. a right wheel mounted on the left side)? It may seem like a dumb question but I need to replace a damaged original rim and I've located a replacement but it's for the wrong side. Thanks.
