Dec 19, 2021
1
'88 Corvette
hey friends, newbie here.
I have a '88 C4 with the factory Ac delco-bose stereo system however only one speaker works faintly. the head unit works beautifully however.
is it possible to have the factory radio head with aftermarket speakers? I've heard a few things that say its not possible because of the speaker setup. is this true?
-best
your speakers have individual, proprietary, mini amps, at each speaker itself.
you can buy replacement amps for them and swap them easily. well....the front door speakers are a process to get to but there are two youtube vids demonstrating the process.
there is a guy in calgary/airdrie who sells the replacement amps for $100 each. he advertises on kijiji.
Alternatively if u r good with soldering, you can simply replace the capacitors that go bad yourself.
Also note, there is a kit offered that ties into the factory head unit, that allows you to run an aux-in port. I did that on my 87 and plugged an “mpow” bluetooth gateway into said aux port and voila i had streaming bluetooth and handsfree calling in my 87 👍
