C4 Radiator replacement
Oct 16, 2016
13
2
3
Hamilton
Best answers
1996 C4 Convertible
Reactions
2 0 0
#1
I have a 96 LT1 and because of overheating issues (during summertime stop & go traffic) I am thinking of replacing my radiator.
Note my 96 only has 20k original kilometres (sat for extended period as original owners only drove about 500 kilometres a year), I’ve already had the rad flushed and antifreeze replaced.
Has anyone replaced their radiator and if so did you replace with stock or with an aluminum 2 or 3 core radiator?
Did replacing the radiator solve overheating issues?
Thanks
Derek
Jul 11, 2013
456
81
28
Scarborough, Ontario, Canada
Best answers
85 & 87 Coupes
Reactions
82 0 0
#2
I replaced mine with stock equivalent. All overheating was solved. Mine used to go up to about 265f even with flush and new thermostat and waterpump. Now runs around 190 - 200f. I have heard that aluminum is lighter , but tends to be less efficient than steel/copper.
OP
OP
DL-Hamilton
Oct 16, 2016
13
2
3
Hamilton
Best answers
1996 C4 Convertible
Reactions
2 0 0
#3
Thanks Vintageracer what make of rad did you get for the replacement?
Dave91TM
May 14, 2011
79
26
18
Barrie Ontario
Best answers
1991 Coupe
Reactions
29 0 0
#5
Same goes, I replaced the rad with a stock unit as recommended by Manny Da Silva...excellent result.
Temp gauge may occasionally get to the 1/2 mark in traffic.
Good Luck.
Vette1993
Jun 30, 2018
11
11
3
Best answers
1993 Vette 40th 6sp
Reactions
13 0 0
#6
What is the "normal" operating temperature for the average C4? My 86 crept up to 217 in traffic, and then touched 230 in my driveway. The day was hot, around 90. Got this car a short while ago, but rad cap seems good, maybe recent, antifreeze is clean, bright green, hoses look fine. Scares the hell out of me, don't wanna blow up a good engine. Car has only 50000 miles on it (82000 klms) Should have a 195 degree thermostat in it, (factory) but the fan seems to kick in only when it's really hot.
Jul 11, 2013
456
81
28
Best answers
85 & 87 Coupes
Reactions
82 0 0
#7
Your experiences are similar to mine. I get about 210 in traffic on hot days and high 220s after pulling into the garage at shutdown. Driving in Summer runs around 185 - 200 normally.
Before my new rad it would soar to about 260:Arghh:!!! (fortunately, no apparent damage)
Vette1993
Jun 30, 2018
11
11
3
Best answers
1993 Vette 40th 6sp
Reactions
13 0 0
#8
Been reading about how important it is to keep the rad free of debris, seems the design of the air inlet, low to the ground, causes a lot of stuff to get sucked up. Carefully ran the garden hose through the rad from the inside to wash off debris, so I'll see if that helped.
Corvette LT4
2000 FRC C5
C5 Owner
Jan 4, 2018
6
Montreal
Best answers
2000 FRC C5
Reactions
0 0 0
#9
These are normal temperature for those C4’s
Fans starts at 224 and 228, if you want to run cooler, have the PCM tuned to start the fans earlier
Vette1993
Jun 30, 2018
11
11
3
Best answers
1993 Vette 40th 6sp
Reactions
13 0 0
#10
Okay, thanks for the advise. Sprayed the whole radiator carefully from the inside out with a garden hose, hopefully washed off a lot of stuff. I'll see if that helped.
