It's just my car cover. I couldn't imagine that much snow covering my car.
The harness bar mounts very nicely to the B-pillar seat belt locations. The stock shoulder bolt and plastic cover do not work with the bar. The original hardware comes with all the appropriate washers, spacers and bolts. However, I didn't get that, so I had to do a bit of research and some trial and error to get the right set up. They remanded of the bar, the side supports mount to the rear seat track bolts on the floor. You just use the nut that's there in the track. They should have designed it that way for the B-pillar mounts. Oh well, it wasn't too bad to put together although you may want a extra set of hands to help you support the bar when mounting it so as to not scratch the plastic surrounding the seat belt bolts.
