Brake boots for the G35
329
460
2005 C6 Z51 6 spd
BC
This came in the mail today. Overnight parts from Japan! Well not quite overnight.
The left front brake stuck recently, one of the piston boots was torn, and I think it was bunching up against the piston because when I pulled it away the brake worked fine. The boots have a tapered edge that fits into a slot and can apparently be easily removed without removing the piston, so I thought I'd give it a try as the front calipers are only 4 years old so I'd rather now throw them away. I also ordered new slider pin boots as they're easy enough to change while in there.
iVCcTqnNKg9giYv6yoWCIg5rPG4cfVAjnTRyiTl3CeHQmmO8xk3v37nyg3hibeRGPBDIw-EfXyQNT4Vz0_iU6kOhpzghmO2Piph38aqkroBtRsKNBqYB66Mcog9oNe3xDiJ0PtLkN_-wpzfEa4pwjitX3rBJAncM5e-cefbiAff33MctWmuIq9_FzUVaQQQSU-D_P67oWzoihxdzLUUymYwwwOLuxapN25MIewgUDfb_eunlHG3FKtW5T-HxyolGrkHRbhZn0gtp2cjgdsxSfAwZxwDsHBEDTRqJqOjfFsInENHdbGnsXiBtLYz2GLpmp6rhd2mOnDkk0vDz_ONhpbjnRhunWDRrLzdBki03qfj0ARaOzpHN-cIfiz-f38bBcV5dDYNKsAFS26RCsKqbZukNPVzl7s6-ftJWsq93lpAJv0XxMxBD3XxfckErdWb1XPnoHOZi57tOvuZ1INK5KSxDc-xYNrO36Ak9kgtuF0Rk9hihbaem1JvJ2B9Y3186XF9nv5A6jV_oyXkqpNfNeBinAgVFDm82SPbr5HuokBYspxdttcLrXzD1WlDWXJ6vp11K4NbI4D-UqbfUdY73acZLJcgtqrpUgIT7Bzj_6Wq2xpaj60PZi4tso_IXiQnQluCb5mPME62m5OjdXtNu7WgsUd1YBLtX9XJvbKsyV6hSPlG7RlTobscNHwRz=w1278-h961-no
