Had this setup forever on every m/c I've owned.
I don't understand that ground, but whatever.
I would wire up direct to the battery....easy peasy.
I like batteries to only have factory cables on them. Especially side post.
Grounds are hard to come by on a fiberglass car, so I am assuming the ground he is illustrating here was the closest one around. But I will be looking for another.
  • Agree
Reactions: AxeZ06 and hemicat
Same here re adding wires to the battery terminals. But, the eye rings that come with a Tender Jr can't be more than 1/32" (just looked at mine....took a pic) Space isn't an issue, install is simple.
If y'all run it similar..... Don't forget to use an inline fuse, if it's not supplied.
