Anyone buy mud guards from GS Creations?
134
121
2022 Z51 Coupe
Looking to grab a set of extended rear mudguards & so far the only options I've found either require you to buy both front/rears & are incredibly $$$. ACS Composites' full is set is $646 and Extreme Online Store is US pricing, will run close to the same amount after taxes, shipping etc. Amazon has some but they don't appear to be extended & are likely low quality.
I've found extended rear's at GS Creations which should come in <$200 after taxes and appear to be US made, but I've never heard of them. Wondering if anyone has bought from them before and/or has a good option for extended rear mudguards? Thanks!
Haven't dealt with that company so can't answer your question (sorry).
I see that eBay has some "extended" mud flaps for sale for the C8 @ US$99 but I'd be wary of purchasing them since they mention not coming with hardware and also mention bolt-on installation:
Plus when looking for these extended mud flaps, be careful since every C8 comes from factory with black composite "rock guards" installed in each wheel well. Some people mistakenly refer to them as "mud flaps" whereas they barely stick out the sides and they're really only there to protect the inner wheel wells from debris strikes. I've seen people reference the regular size GM OEM mud flaps (GM part numbers: 84263453 front; 84263457 rear) as the larger/extended versions whereas they're not: they do stick out more than the rock guards but the true extended mud flaps stick out further than the GM OEM flaps and are only available from after market vendors. So the question is whether GS Creations sell the truly extended version of mud flaps or the same size as the OEM mud flaps. You may want to contact GS Creations to confirm before you plunk your money down. Hope this helps.
