The members here that have a QJ and have used it for a while what I want to know is how often do you bleed the hydraulic cylinders the whole time you have used your QJ?
I know in the initial setup instructions after you purchase and assemble the unit you need to bleed the cylinders so your frames move smoothly but after that first time bleed have you done this step again and if you have how often?
I have the 7000SLX and I've done the bleed process numerous times during the 3 years I have owned mine.
Tony
Tony
