Hi...I have a 2019 M7 with non electronic LSD, that I would like my indie garage to, amongst other services, change the rear differential fluid. Running into a bit of a roadblock with the GM recommended fluid (below) that contains an LSD additive (Canadian part # is the same with a '5' as the last digit). Even amongst GM dealers, it is apparently difficult to find, and the one dealer who offered to order it would only do so if I bought a whole case of 12x 1L bottles.
Couple of questions for anyone who has had experience with this...any sources for this fluid in the GTA? Also...although my owners manual has some fluid capacities listed, the differential is not one of them. Checking online, it seems that it takes about 3L of fluid...is this correct?
Thanks in advance...Robert
