Hello, I’m new to the thread and and didn’t receive any replies and it was probably the title. I’m a new owner of a 66 /427 and I’m concerned with what fuel is correct. Is an additive also required? Thanks Great blogg
Many Thanks, very helpful. Lol Hopefully the car is as good as my research leeds me to believe.Haven’t seen it yet.
Hi Bruce, Based on those few pics you've posted, that is a fabulous looking car and in great shape. Congrats!
There are 2 versions of 427 for 66. I see a 6500 tach redline on the picture of your interior. If its the original engine, then what you have is a 425 HP, High Perf engine, running 11.0:1 compression. That is a very strong big boy that is very thirsty and needs lots of protein!
These Mark IV engines in the late 60s were not designed for Ethanol, and unleaded fuels. So you should definitely follow all the good recommendations you've already received, and go for the highest Octane grade fuel with No Ethanol, that you can find.
You should also consider adding a container of lead substitute with every fill-up to protect the valve stems and seats. Before unleaded, leaded fuels inadvertently helped protect the valves by creating a lead particle build-up on the seats that acted as a cushion and softened the blow each time a valve closed and contacted on its seat. There are plenty of articles around saying they have had no issues with the valves when running unleaded. Maybe its just a placebo, but I prefer not to take any chances.
One little note. If you are like most drivers, you will occasionally find yourself looking for a gas station in the middle of nowhere and end up having to fill-up with whatever fuel you could find. So always store some lead substitute and octane booster in your car just in case.
Enjoy your new ride!
Luke
Luke
