72 corvette fuel vapor smell
Wes4975
New Member
Mar 11, 2018
5
7
Denver
Best answers
Reactions
7 0 0
#1
I recently bought a 72 corvette. My car emits gas fumes for several days after I drive it. I heard it could be the charcoal canister , but I can't find a replacement for it. Any advice would be appreciated .
taylorsk8
C3 Owner
Jan 25, 2009
1,070
226
Saskatoon
Best answers
73 Corvette Coupe
Reactions
226 0 0
#2
That would be the best place to start. Not sure where you can get replacements but I will look around a bit.
T
turbozig
It's not just a car, it's a state of mind
C7 Owner
C3 Owner
Jun 21, 2011
936
1,652
Edmonton
Best answers
1970 & 2015 Stingray
Province / State
Alberta
Reactions
1,648 4 0
#4
I would recommend checking all the rubber fuel hoses at the pump and back at the tank. My 70 hoses were all original, cracking and brittle. They were weeping from the connections. A quick and relatively easy fix. Also check the fuel sending unit gasket on the bottom of your tank. The carburetor gaskets and fittings are also something to check first. Best of luck.
OP
OP
Wes4975
Wes4975
New Member
Mar 11, 2018
5
7
Denver
Best answers
Reactions
7 0 0
#5
Thanks, I'll check, just noticed I did not have a gas cap gasket
nascar03
C5 Owner
C3 Owner
Jan 27, 2009
3,150
2,226
Township of Langley, BC
Best answers
1975 coupe/2003 vert
Province / State
British Columbia
Reactions
2,223 3 0
#6
My ‘75 had a fuel vapour smell many years ago...I couldn’t figure it out either.
A couple of months later I was under the car cleaning and generally poking around.
I found some dirt/sand built-up in an area on the frame rail just ahead of the rear wheel.
When I started cleaning with a small brush I realized this was ‘caked’ around the fuel line next to the frame..
The line had almost rusted thru due to this build-up of dirt holding moisture.
I cut out the bad section of line and replaced it with a length of the best rubber fuel line I could buy.
It is now a regular part of my 5-year maintenance to replace that rubber line.
Ya never know where that leak might be coming from.
Having a fuel leak is not good.
Good luck
Graham
Jan 1, 2014
209
128
Calgary AB
Best answers
Reactions
127 1 0
#7
I had the classic old car gas smell for years. It was fairly strong and always made me wonder if I had a gas leak somewhere. I checked the canister, the lines, and the gas cap (those do wear and need to be replaced), but the gas smell never went away. When I switched to an efi setup the gas smell went away. Now it is a bit expensive but if it bothers you it might be the solution. You get other benefits along with better fuel economy, usually more power from an extremely accurate tune, and drivability especially on long road trips where you’re going to be changing elevation. They also have somecost effective options like Fitech and the Holley Sniper.
If you’re feeling bored one winter, I’d recommend cleaning up your gas lines, as long as they’re in decent condition. That would really suck to have a line rust through on you like Graham’s. A few winters ago I was doing an engine swap and had the fuel lines disconnected. Cleaned them up with a red scotch bright pad, polished them, then clear coated them with POR 15. They turned out very nice and it gives me piece of mind knowing there isn’t any rust working it’s way through them.
Black 03 Z06
C5 Owner
Oct 30, 2013
6,452
5,583
Haliburton, Ontario
Best answers
2003 Z06
Province / State
Ontario
Reactions
5,558 25 0
#8
Soon good safety/maintenance information here.
Good luck getting this issue sorted out.
Rruuff Day
Patiently Waiting for Spring
Beta
C7 Owner
HOT Dealer
Top Poster Of Month
Aug 30, 2014
5,778
5,276
Pine Lake, Alberta
Best answers
C7 3LT ZF1
Province / State
Alberta
Reactions
5,260 16 0
#9
OP
OP
Wes4975
Wes4975
New Member
Mar 11, 2018
5
7
Denver
Best answers
Reactions
7 0 0
#10
iOS Image - 1011168686.jpg iOS Image - 3406938729.jpg iOS Image - 538980682.jpg
Yeah, my first, I joined up so I could learn. But I love the car so far
nascar03
C5 Owner
C3 Owner
Jan 27, 2009
3,150
2,226
Best answers
Province / State
British Columbia
Reactions
2,223 3 0
#11
I love chrome bumper cars.
Graham
Black 03 Z06
C5 Owner
Oct 30, 2013
6,452
5,583
Haliburton, Ontario
Best answers
2003 Z06
Province / State
Ontario
Reactions
5,558 25 0
#12
Very nice looking car. Graham is right, those chrome bumper cars are beautiful.
Good luck with yours.
MikeysZ06
C6 Owner
May 3, 2017
2,734
2,757
Calgary
Best answers
2007 LeMans Blue Z06
Reactions
2,742 15 0
#13
The kayak is pretty nice too. :thumbs: I love the rear end on those C3s.
Rruuff Day
Beta
C7 Owner
HOT Dealer
Top Poster Of Month
Aug 30, 2014
5,778
5,276
Pine Lake, Alberta
Best answers
C7 3LT ZF1
Province / State
Alberta
Reactions
5,260 16 0
#14
OP
OP
Wes4975
Wes4975
New Member
Mar 11, 2018
5
7
Denver
Best answers
Reactions
7 0 0
#15
Anyone know where to get a charcoal canister?
Keith Tedford
C6 Owner
Apr 30, 2012
3,563
491
Ontario
Best answers
2005 C6 1SB
Reactions
488 3 0
#17
Try a wrecking yard if you can't find a new one. They have been around for a long time. The '72 Lemans Sport that I did over in the 1990s had one.
Jan 1, 2014
209
128
Calgary AB
Best answers
Reactions
127 1 0
#18
Western Corvette is also a good source if you live near Calgary. They have some parts cars and a bunch of spare parts. If they don’t have anything used they might be able to source you a new one. I looked at corvette depot and it doesn’t appear they sell one.
