While putting my ‘67 back together I've run into a potential issue with the Clutch Rod. Yesterday I installed the clutch/brake pedal assembly but when I hooked up the clutch rod it’s extremely close to interfering with the top of the firewall opening.
The body is on a replacement frame that may have originally been a big block Vette, don’t know if that makes any difference. New body mounts installed all around. I’m not sure how it originally was before this work was started but I was expecting it to go thru the firewall opening, close to the middle of hole.
Here’s a pic of it from the inside as you’re looking down the clutch rod to the firewall opening. Does this look right or have I done something wrong? With how that pedal assembly mounts to the firewall and Z-bar, I don’t see what options I have except for shimming between the pedal assembly plate and the Z-bar. I don’t remember any shims being removed from that area and can't find anything in A.I.M. about shimming it.
Let me know if anyone has seen this before and fixed it or if you think this is typical. I’m concerned that if the body mounts start to sag at some point it could make things worse.
