Hey guys. I'm considering installing a 4 post lift in my mancave. PA has a Torin 9000 lb on sale at the moment. Would appreciate any advice you can offer. Thanks.
I like horror stories. Bring it on Jeff.They are great I will reply later with a horror story I had 2 weeks ago
Thanks Al. Haven't committed to anything yet... Still deciding and garnering advice. Hadn't seen you around here for a few. How's the new job?Well, I am on lift #3 so here’s my perspective. Firstly, look very carefully at the lock disengagement mechanism. Not that you have to worry about it crashing down but the long term headache of the multiple angles that some have in their disengagement linkage. My Lift King drove me bonkers as it was constantly needing TLC at the linkages weak point. On several occaisions the Lift King’s crazy linkage setup wouldn’t release a lock and before you know it you have a serious problem. Secondly do not bolt it down. There is no need. Thirdly what set-up are the back up locks in case of failure of the main lock. No need for 220 power. 110 works fine just a little slower.
If price is not the determining factor I wouldn’t stray to far from a Bendpak lift. Currently I have a Bendpak XL9000, which is an extra wide 9,000 pound lift. It will handle a 1 ton. The Bendpak needs an air compressor as it uses an air de-locking system. The latches will not release unless 90 pounds of air forces the lock open. As well the lock cannot open with weight on the lift.
Couple of safety tips with all of them. Firstly unplug the lift at all times when you are not babysitting it. The cheap hydraulic power switches have been known to fail and power up a lift when no-one is around. Hate to see Ginger squished into the ceiling. Secondly always check your locks after you finish lifting the car. Thirdly, always walk around your lift before lowering. I have a new pressure washer because the old one magically rolled itself under the corner of the lift when I wasn't looking. Fourthly, mark on the post you can see when operating the pump, your max height, with a sharpie. Not paying attention can cause heartache. Especially if you have a lower garage ceiling and cannot use the max height of your lift. Remember that you need to lift a couple of inches higher when wanting to lower, as you have to lift up to release the locking mechanisim.
They are not that difficult to assemble but two guys is definitely the ticket. The ramp with the hydraulic ram will be heavy.
PM or call me Eric if I can offer you any other pointers.
Things are good, just crazy busy with seling acreage, buying new place, and oh ya the new job.Thanks Al. Haven't committed to anything yet... Still deciding and garnering advice. Hadn't seen you around here for a few. How's the new job?
What is this carless you speak of....lol. Seriously the castors are a great option. I have rolled mine out onto the driveway, put the car on the lift and hoisted her up. Great way to pressure wash the undercarriage.I echo Cariboocreeks' comments. I have had my Bendpack for about 9 years and zero issues. I like their safety features and the fact that it does not require bolting it to the floor..... (I had sleepless nights over that feature but obviously no issue). Another bonus is the optional caster set.... 4 large heavy duty casters that are an easy on, easy off process, (no need to bolt or unbolt anything) and you can move it (carless of course) anywhere in your garage or outside.
Thanks Bob. Will have a look.I have had a couple lifts over the years and sure miss having one now but our garage here is way too small. The last one I had is similar the Advantage Lifts advertised on Kijiji here. Advantage Lifts: DX 9000XLT | Cars & Trucks | Calgary | Kijiji
I really like the way the lift platform corners fully enclose the posts. Price is a bit higher than PA but might be worth looking at as another option,Page not found | Unique Motor Vehicles
A Selection of Unique Motor Vehicles in Calgary, Albertauniquemv.com
Good luck getting them to return your call.Thanks Bob. Will have a look.
This is on my wish list for the summer and I am concerned about what is required for the garage door. I have 11 foot ceiling. Is it just having a garage door guy come in and raise the bend point so the door opens near the ceiling? Is there any restriction on using the electric opener. Would appreciate advice from those who have done this.Great thread. Will be doing this in the fall/winter after I adjust my garage door to allow for added height.
An 11’ ceiling is more than enough. Depending on the overall size of your garage you may want to look at getting a side opener. The standard garage door opener hangs to low and may be in the way when you raise the lift. I put a side opener on mine and modified the rails for $1500 installed. Had an overhead garage door installer come over and do all the work.This is on my wish list for the summer and I am concerned about what is required for the garage door. I have 11 foot ceiling. Is it just having a garage door guy come in and raise the bend point so the door opens near the ceiling? Is there any restriction on using the electric opener. Would appreciate advice from those who have done this.
