2008 C6 Roof Creaking Nouse
Z51
Jan 28, 2010
179
Awards
4
Komoka Ontario
Province / State
Ontario
  • Ontario
  • C6
  • You're 5
  • You're a Regular
I know I cannot be only one that the roof makes a creaking noise. What lube do people use to stop this .
12cents
Jun 26, 2014
720
857
Awards
6
Far East of Canada
Centennial coupe
Province / State
Newfoundland & Labrador
  • You're 5
  • C6
  • NL
  • You're Celebrated
  • You're a Regular
  • You're Liked
I have put lubrication all over the rubber seals and pin holes plus double walled heat shirk on the two front locator pins. It hasn't completely stopped the annoying squeak but it has certainly reduced it. I find sometimes that I have to release all the clamps and redo them again but in a different pattern of tightening.
Reactions: KevinB
12cents
Jun 26, 2014
720
857
Awards
6
Far East of Canada
Centennial coupe
Province / State
  • You're 5
  • C6
  • NL
  • You're Celebrated
  • You're a Regular
  • You're Liked
What kind of lubricant do you use?
It was a silicone based lubricant. I don't remember the name now. I will check tomorrow in the garage to see if I still have some left.
The brakes are known for squealing if not used hard once in a while. My understanding is the pads have a tendency to glaze over a bit if you are too gentle. A couple of good hard stops done in a safe manner should be able to clear it. As soon as I even think I hear it, I find a spot to safely stomp the brakes hard. I have been able to do it without hitting any high speeds.
  • Informative
Reactions: ddgermann
Creedence85
Jul 12, 2018
102
138
Awards
4
Richmond, BC
2005 C6 Z51 6 spd
  • C6
  • You're Celebrated
  • You're a Regular
  • You're Liked
I followed this guide:
When I did it the first time last summer, my locating pins needed tightening, and there was dirt on the contact points. I didn't have any of the GM weatherstripping lubricant, so I just used silicone lube. My top wasn't too loud to begin with, but it did seem a bit quieter after servicing. I just serviced it again a couple weeks ago, the pins didn't need tightening, and there wasn't much dirt.
Sadie
New Poster
Feb 3, 2019
8
3
Awards
Thank you for the brake advise.
I have seen this video, and asked for the part number at a GM dealership and they told it didn’t exist. Instead gave me a white paste that got all over the place and dried to a white powdery mess. It did nothing for the squeaky top. Now I always try to drive topless on sunny days. (The car is topless, I wear a shirt)
Rruuff Day
Finally!
Beta
Aug 30, 2014
6,655
6,471
Awards
9
Pine Lake, Alberta
C7 3LT ZF1
Province / State
Alberta
  • C7
  • Alberta
  • You're Celebrated
  • Show Off
  • Hot Chili
  • You're a Regular
Dielectric grease is what i used on my C6. My C7 doesn't squeak or creak. The other cure many talk about is slipping a rubber o-ring over each of the pins. This snugs up the fit and eliminates the creaks as well.
joe299
New Poster
Sep 5, 2018
3
Awards
1
2008 Corvette
  • C6
I had the same issue and drove me crazy! I installed the 5/32" E clips on the pin and I now have ZERO noise. Here is a link for the info:
Canuck204
Dec 6, 2018
39
43
Awards
2007 Z51
The noise doesn't bug me when I'm alone, only when i have a passenger. Nothing better than taking someone for a ride to show off your car, then you catch them looking up the roof with a wtf is that noise look lol. ugh. "The top comes off, its normal!"
  • Agree
Reactions: 12cents
Keith Tedford
3,645
687
Awards
5
Ontario
2005 C6 1SB
  • C6
  • You're 5
  • You're a Regular
  • King of the Post
  • You're Liked
The roof on our 2005 was creaking even with all the rubbers lubed. I got the 5/32 E-clips, installed them and all is well.....so far. With two pair of needle nose pliers I installed the clips without having to remove the handle from the roof section. Thanks to those who came up with the cure. It sure was simple. The creaking could be aggravating if you drove on many rough roads.
  • Informative
Keith Tedford
3,645
687
Awards
5
Ontario
2005 C6 1SB
  • C6
  • You're 5
  • You're a Regular
  • King of the Post
  • You're Liked
do you have a picture?
Scroll back up a ways and Joe299 posted pictures. The hardest part for me was lifting off the roof to work on it. I'm not as young as I used to be. We were out to a cruise night this evening and all is quiet. Thumbs up to Joe299.
