2005 Corvette PCM Manual Transmission
2005 C6 Z51
Price
$0
Hello everyone,
Collin here. Myself and Race Ready Garage are desperately looking for a manual transmission PCM for my 2005 corvette that is stuck at their shop and unfortunately not in my garage to be driveable.
Please if you know anyone that has one for sale or can direct me to a reputable preferable local place to get one is much appreciated.
New , used or refurbished don’t care just need one.
Don’t want to have to buy from Joe in Missouri who promises to send it.
Again, PCM for 2005 Corvette E40 is the style 2 short one long port and has to be from manual trans
Thank you
Hello everyone,
Thank you
Found this. I hope it helps some …..you certainly chose a top line shop to do your work !
You can buy a 2005 Corvette E40 PCM from several sources:
• Online auto parts sellers like FS1 Inc offer plug-and-play programmed PCMs for the 2005 Corvette 6.0L LS2 engine.
• Programming services such as LT1Swap.com provide E40 PCM programming and re-flashing for LS2 Corvettes, which may be necessary if you buy a used or unprogrammed PCM.
• Corvette forums and eBay sellers often provide used E40 ECMs with reprogramming services included; you send them your VIN and they program the PCM to match your car.
• You can also find 2005 Corvette manual transmission cars for sale on platforms like Kijiji Autos, which could be a source for a donor PCM.
For standalone harnesses or wiring support, specialized vendors like BP Automotive have Gen IV E40 LS2 standalone harnesses available.
If buying used, ensure the PCM is from a manual transmission Corvette and get it programmed for your VIN and setup for proper operation. Programming services typically cost around $150 plus shipping.
You can buy an E40 ECM for a 2005 Corvette LS2 from several sources:
• PSI Conversion offers an LS2 Engine E40 ECM with programming for 2005/2006 models, including removal of VATS and other updates, priced around $950 (note: for off-road use only).
• PCM of NC sells replacement E40 ECM cores that they program with your VIN and GM operating system for plug-and-play use. They do not require a core return and offer optional VATS deletion for $50.
• NextGenPartsPlace lists a 2005 C6 Corvette 24X E40 ECU/ECM OEM part for about $499.99.
• LS Wiring sells genuine OEM E40 ECM connector kits if you need connectors or wiring components.
• Corvette forums and tuning shops like BenchForce provide programming harnesses and support for E40 ECMs, as these units are becoming rare.
For best results, ensure the ECM is programmed correctly for your vehicle and consider professional tuning if you have aftermarket modifications.
