Early cars had steering lock issues. Was subject to recall. Some had balancer lower pulley wobble, some had cracked rear spring/separation issues, some are prone to rear axle seal weeping or worse, most valve spring issues ended late 02. I my car was built early August of 2002. I ordered it and it just turned 9,000 miles. It has had 2 of these issues. Still recommend getting the GM report. Great document for your file. It’s free too. He must have service receipts, ask to see them. Black is a tough color to maintain to a high level. Inspect it very closely get it on a lift and look under the front nose especially the lower air dam and support struts with a high lumen light, you’ll be surprised. Rock chip damage in back against mufflers/area and in wheel wells. Wear on seat outer lumbarsIs it an FRC?
I suppose the tires have changed and battery too. I still have my originals. What’s the dates on the tires?
