Hi there everyone!
A new 1987 C4 owner from Kitchener-Waterloo, joining you here. Just picked up our Nassau Blue (Medium Blue) C4 last week, we trailered it home since it's so cold here! -15C is not ideal weather to be loading a car, but you do what you have too.
The car is blue on blue with about 117,000 kms on the odometer. 4+3 Doug Nash manual, which I believe was required in '87 for the Z51 packaged. Overall, optioned pretty highly. The last owner only put about 3,000 kms on it in the last 3 years, so needs full servicing and tune up to bring it up to our standards. In good shape otherwise, though.
One thing I'm already learning from reading some of the last threads here, is the availability (or lack there of!) of 255/50R16 tires. The DOT dates on the current Dunlops is 2003, so they are just too old to try and eek any further life out of them. I've been searching everywhere for BFGooderich g-Force Sport Comp-2 tires, but there are just none available. Don't want to give up on them, but seems it's also true they may no longer be produced. Hope they change their mind! Anyone heard any further updates? My sources here say they have no production date set in the system.
I'm aware of some of the Toyo Proxes options (RA1 and R888R), however, my plan is to regularly drive the car from May - Oct. Not sure how well these tires would be on the street, especially in the Spring and Fall temps. The final option is looking at 245/50R16 tires. These are not that common either, but I do have a source for some Cooper Zeon RS3-G1 tires in stock and available. The car has the 9.5" wide tires, so I understand the 245 might be right at the minimum.
If anyone has an other tire ideas, or comments on running either the RA1s, or running 245s, I am all ears!
Look forward to learning as much as I can from all of you, and thanks in advance for your help.
Josh
Josh
