1976 Flywheel and Starter
evandermaarel
Sep 29, 2017
35
9
Awards
1
St. Thomas
  • C3
I have a 1976 that I bought 6 years ago and was in storage. Just started working on it with my son as a project and found the previous Owner stripped the flywheel gear and the starter pinion. I am looking for step by step info and guidance to perform this work.
Thanks for the help!
XFIRE82
MOTM
XFIRE82
1,388
1,785
Awards
9
Krydor, Saskatchewan
3
Province / State
Saskatchewan
  • C3
  • C4
  • SK
  • You're Celebrated
  • Spotlight Award
  • Hot Chili
...ouch ! , you have a job ahead of you. The reason they stripped may be cause they were not meshing when starter drive engaged, something that shims between the block and starter can fix. Or the starter was lose and the guy just kept grinding away ? Anyways the starter is easy, the flywheel you have 2 choices. Either drop the transmission to change the flywheel or pull out the motor to change the flywheel. Flywheel is a one minute job to switch, but the work to get at it is the killer. Also I would suggest getting a factory shop service manual for your car, they can be very helpfull in doing any mechanical work.
evandermaarel
Sep 29, 2017
35
9
Awards
1
St. Thomas
  • C3
Thanks . I think I will pull the motor and paint the firewalls at the same time.
Reactions: ddgermann
gdh
Jul 26, 2015
62
35
Awards
1
Orangeville
1972 Convertible
  • You're a Regular
No, once you have everything out you have access to both, neither are expensive parts and you have peace of mind for 10's of thousands of miles/km.
XFIRE82
MOTM
XFIRE82
1,388
1,785
Awards
9
3
Province / State
Saskatchewan
  • C3
  • C4
  • SK
  • You're Celebrated
  • Spotlight Award
  • Hot Chili
While you're at it replace both the throwout bearing and clutch release bearing.
...he didn't say if auto or std tranny , but if a auto ( my guess it is ) then there are no bearings. and if it is a std then might as well put a new clutch and pressure plate too while all is apart.
  • Useful
rick coldin
Dec 11, 2018
31
14
Awards
69 convertible 427
the throw out bearing and the clutch release bearing not to be a smarty pants but that's 2 terms for the same bearing
